EGR Pipe Replacement
Need help!
Apparently it is possible to replace a cracked EGR Pipe without removing the intake manifold or dropping the tranny.
The vehicle is a 94 LS 400. Does anyone know the procedure for doing this?
thanks, damon
thanks, damon
It can be done, but I found that removing the tranny and do the rear main seal and EGR pipe at the same time is easiest way ( for me).
PM, Sooner, I think he got a trick to do the EGR pipe without removing the intake or tranny.
EGR Pipe assy. Replacement
90-94 LS 400 ( Non-California )
Replacement Info:
From Beneath the vehicle:
Remove the two 12 mm nuts from the rt. side of manifold where the EGR pipe connects.
Remove 12 mm bolt at the back of the block, visible by looking between the right side of the transmission and the exhaust.
Above the vehicle:
Remove two 12 mm bolts at the top of the pipe assembly and slowly slide the assembly out by tilting it to the right.
Reverse procedure to install new part.
Note: The above is paraphrased from Sooners instructions below:
"there is 2 12 mm nuts on the right hand side manifold where the pipe connects to remove those next there is a 12 mm bolt in the back of the block to see this look between the tright sode of the trans and the exhaust remove this the go to the top remove the 2 12 mm bolts for the top of the pipe thin slowly work the pipe out tilting to the right.reinstall the oppostie way as posted this instructions are on for a 90-94 non californian car.and 95's r different". _______________________________________________________________
Replacement Info:
Above the vehicle:
My 91LS transmission is dropped for oil seals replacement. I also replaced the cracked EGR pipe while at it. I must comment that, due to the odd shape of the EGR pipe, physically removing the pipe is not going to be a walk-in-the-park without removing the trans and tilting the engine. Why? Trans, catalytic convertor, and exhaust pipes are in the way, and very little clearance between rear engine block and firewall. Needless to say, I am very happy I spotted a cracked EGR pipe while the trans is out.
Stats: Cal. 91LS
Stats: Cal. 91LS
EGR
hyperopt ,
Can we assume from your current location that your 91 is a California version?
Nice spot to catch this while the trans was down.
A "search" for EGR Pipe here at the forum reveals that many members have paid up to $1000 dollars to Dealers to have this assembly replaced so although it may indeed be tough to do without dropping the Transmission or removing the intake manifold ,it is indeed possible. I believe that Sooner estimated that he can usually perform this replacement in 40 minutes.
Goal here is to make mechanics that participate in the Club Lexus Forum & owners aware that there is a cost & time saving procedure.
Damon
Damon
Done
Tackled this today.
Not much fun. The schematic showed only the 4 bolts referenced by Sooner in previous post as accessible from top or bottom. The real world throws you a nasty curve on a 94 LS, The one he describes as in the back of the block will consume most of your time. Above the passenger side cat you will find 2 studs which are easy to remove from below, towards the firewall on top of the engine there are 2 bolts which are a simple task , but the bolt on the back of the engine above the transmission,( which did not appear on the schematic which I utilized as a reference) that Sooner makes mention of is an absolute bastard!! Very little room between it and the firewall. I would by no means describe it's location as "visible".
3 bolts , 2 studs, 5 connection points total!
RESULTS: Sounds much better , but I had better see a mileage reward before my burns heal. Not kidding!!!
94 LS
Part # 25601-50010
price $116.14 from Carson
Good news is that Sooner is absolutely correct. It is possible to replace this piece on a 94 without dropping the Tranny or removing the intake manifold
94 LS
Part # 25601-50010
The egr pipe on my 1993 ls400 cracked right at the flange where it mates to the intake manifold.
I've been searching the forums and noticed Sooner said the california cars are different. Can Sooner or anyone else give additional details on the procedure for california cars ?
Sooner states the intake manifold must be removed. Is this for clearance to get the pipe in and out ? Looks like I have a clear shot to get to the bolts holding the egr pipe to the back of the intake manifold so I do not yet understand why it needs to come out.
appreciate any advice or comments.
REGARDS
Herm
REGARDS
Herm
Thanks for the info, I'll post when I do the job.
I have the factory service manuals for my 1993 LS400, so far I have been unable to find a procedure or diagram for the egr pipe replacement. Can anyone send me a section or page number ?
Thanks - Herm
Thanks - Herm
