Sick of searching - For real what should I do ?
Ok now what should I replace for my door to lock ? All my doors unlock but does not lock even on passenger side and with the key. What should I do ?
Have you taken the panel off and checked all the brackets and wiring? If not, just remove it and do a quick visual inspection. It could be that someone tried to break into your car and managed to actually disconnect that bracket from the lock and tumbler to the latch. If that's all still together and tight, then check the latch using a screwdriver. Just put the screw driver through the latch and manually try to realease it from inside the door. If the latch works fine then it's time to go to the dealership and get a new lock and tumbler for the door. Hope that helps
CRAIGF
RX - 3rd Gen (2010-2015)
02-03-18 09:45 AM
