How long should I go on these??
Old 03-19-04, 10:46 PM
00GS400L
00GS400L's Avatar
Default How long should I go on these??
I just completed an oil/filter, rear end, tranny fluid change. I used Amsoil full synthetic 10/40, Amsoil filter, Type IV tranny fluid(2qts), and Amsoil full synthetic 75/90 Gear oil in the rearend.I currently have 30,000 miles on my 00GS400. I plan on changing the oil at 5000 mile intervals from here on out with synthetic along with a drain and fill on the tranny.
I was told that the Rearend should be done for the life of the car, is this true?
By the way I took my car to Jiffy Lube with all of my stuff 30 minutes before they closed and offered them $20 to do the labor off the books. They did it. It's not worth $20 for me too put my car up on jacks.
Thanks,
Dean
Old 03-20-04, 09:31 PM
RA40
Super Moderator
RA40's Avatar
My service book has the factory drain interval for the differentail and tranny at 60K miles.
Different thoughts on the tranny drain. <shrug> Mine was fully flushed at the dealer at 58K so I'm going to do the 2 QT drain every 10K miles.
Did you replace the brake fluid? My factory brochure has this at 30K miles.
brad1285
06-13-11 06:57 AM
Alexus02
RX - 1st Gen (1999-2003)
13
09-08-10 11:57 PM
additude
Maintenance
16
08-13-03 03:09 PM
lexian
SC- 1st Gen (1992-2000)
06-28-02 11:56 AM
Quick Reply: How long should I go on these??
