Cap and rotor replacement on 1991 1UZ-FE
How would one go about it? Does the timing belt sprocket cover need to go off after the spark plug cover is removed?
Originally posted by TxLexus
As I remember. Removing the Spark plug cover is all you need. Just dont drop any screws!
Well now you got some more work ahead of you. Start taking ***** off. First remove the battery connecttion before someone accidently try to crank the car. just a precautionary.
I dont remember what all needs to come off. I need to be lookin at the motor. But you need to get the bottom t belt cover off.
atropine
15
08-28-11 07:49 PM
Avery
Performance & Maintenance
07-07-10 05:28 PM
