turn signals will not work on 96 sc400. HELP !!
HELLO,
my turn signals on my 96 sc400 are not working at all. no warning light came on at all. brake lights work, but when you flip the handle for left or right turn, nothing happens.,does not blink at all. i checked all the fuses under the hood and by the drivers side kick panel, and they look fine. i looked at the relay fuses under the hood nd they appear to be fine. could it be the actual turn signal handle that has gone defective?
Is the hazzard switch work? I assume that the all fuses are good. If the harrard switch, then try to play with the turn signal switch and see if the light start flashing. Good luck.
thank you so very much. i put the hazzard lights on, turned them off, and the turn signals started working perfectly. how about that !!! i wonder what causes this? if you know, please let me know. thank you once again !!!!!
sleepybobcat
03-02-02 02:34 PM
