Sheared off screw-how to remove
Old 05-13-04, 07:00 AM
burnettebr
burnettebr's Avatar
Default Sheared off screw-how to remove
I was replacing my amp last night and a screw that holds the CD head into place sheared off-now stuck in the screw hole. Any ideas on how to remove without damaging the threads? Thanks.
Old 05-13-04, 11:35 AM
PERRYinLA
PERRYinLA's Avatar
If the bolt is large enough, you can drill a hole down the center and insert an "easy-out" (sold in hardware stores) to back it out.
Old 05-17-04, 02:39 PM
mikeloc24
mikeloc24's Avatar
I knew THIS guy would know how to handle the problem Only thing is since he's dealing with a damn amp screw it's most likely small, so drilling the length of the shaft would pose a problem.
Old 05-27-04, 11:05 AM
dean s
dean s's Avatar
Default screw removal !
Hey had this problem on a set of heads on my bike .and if you go to a good auto supply store they have drill bits that have a reverse twist to them,as you drill into them with your drill set for reverse they will pull the screw out .worked like a hot damb! oh yeh ,make sure that you set your drill at a slow speed otherwise it'll skip all over the place and make a hell of a mess! you might want to get two of these bits incase one breaks being they are going to be pretty thin .[ you don't want to go back twice, like me!]
good luck!
takadakeyo
07-02-13 09:41 AM
ontoy
03-06-10 03:43 PM
Rx900
Automotive Care & Detailing
08-11-04 07:15 PM
dj.ctwatt
Lighting
04-23-04 07:49 PM
BLexACK LS
Maintenance
07-14-03 07:04 PM
Quick Reply: Sheared off screw-how to remove
