switching to synthetic...
it's time again for an oil change on my GS4 with 60k miles...
would it be wise to switch to synthetic now? or should i
stick to regular oil? i'm thinking of using Mobil 1 5w30.
my regular interval now is 3000 miles.. what should be
the interval for synthetic? leave me some feedback..
Super Moderator
I have extreme conditions for my 99 RX and I use a 3,000 max miles for a change with Mobil 1. I took a trip of 5,000 miles recently (roundtrip) and oil was a little burned.
You guys need to go to "bob the oil guy websight". He tested different oils and filters, had the oil tested at different intervals etc. Engine wear increased during the first 3000 miles after an oil change then dropped until 6000 miles. If you are changing you oil every 3000 miles you are wearing your engine out. I know it is contrary to what jiffy lube and there GED graduates have always told you but it is hard to contradict scientific data. Lexus recommendation of 5000 miles on dino oil is about right. If you use synthetic you can easily go to 10,000 miles and if you change the filter and top off, 18,000 miles. It appears the addiditives in oil get better with aging.
synthetic is fine and change it at 5000 miles. That is what runs well with me. My engine is the 1MZ-FE, and I would not go over 6000 miles between changes EVEN WITH synthetic.
beware, you have opened pandora's box with this question as you will get heated arguements from both sides (pro-synthetic vs pro-dine). Just search the topic and see for yourself.
The bottom line is to go with what you feel comfortable with.
steviej
steviej
on the car makers that suggest >7500 miles, check the volume of oil required for the car. I think you will find most of the cars that allow extreme high mileage changes have greater than 8 quarts of oil on board.
I have even seen some oil capacities of 13 qts. This adds to the allowance of greater intervals.
I think the GS capacitiy is 6 qts and the ES capacity is 5 qts.
steviej
steviej
5,000 mile oil changes with synthetic oil is fine, I wouldn't go past 6,000 or 6,500 IMO.
Also depends on the environmental conditions your car is exposed to as well as how "hard" a driver you are.
I suggest an oil analysis so you know how/what the possible wear characteristics are for -your- engine. While you can follow the maintenace schedule, your driving patterns may have effect on your drain intervals...this can only be determind by analysis.
It is a very resonable cost to check on how your engine is doing, there area variety of labs to select from and most will cost about $20.
![Thumbs down](https://www.clublexus.com/forums/images/icons/icon13.gif)
5000 and 6000 mile oil changes are adequate ONLY under the most ideal of conditions for oil.....moderate temperatures, light engine loads, constant engine speeds, clean air and lack of dust, long trips to get and keep the oil warm, etc...... Most of us, most of the time, don't drive that way. For those who do, fine.
