Squeaking clutch
Old 05-18-04, 11:23 AM
buggsc3
buggsc3's Avatar
Default Squeaking clutch
When I step on the clutch, I hear a loud squeaking sound,(like a door opening). Does anyone know what may be causing this. Pressure plate maybe?
Old 05-26-04, 12:23 PM
Camshaft
Camshaft's Avatar
Throw out bearing. To replace you have to pull the transmission. When you do replace, do NOT use anything other than Toyota parts, or else it will chirp even more. Also, you might want to take a small spray can of lithium grease and lube up the pedal. The clutch is hydraulic, so there are no cables.
Old 05-26-04, 12:26 PM
mooretorque
mooretorque's Avatar
Talking
Camshaft is, as usual, on the money.
Prior to the GS, my whip was a 93 SC 5 spd (and that's precisely what I had to do for that problem).
ccotenj
SC- 1st Gen (1992-2000)
17
09-05-15 09:14 AM
Biggu
Performance & Maintenance
08-07-08 05:36 PM
zegnaguy
10-19-06 10:02 AM
engIs300
IS - 1st Gen (2001-2005)
09-30-06 09:40 AM
blknfury
02-01-06 05:32 PM
Quick Reply: Squeaking clutch
