toyota fuel filter for sc300
does anyone know the toyota part # for fuel filter for the 92 sc300.?? should i use stock fuel filter or use aftermarket ones??
Originally posted by bishop977
i called up my local toyota dealer and they didn't have it? do you have the part #? i called local lexus the filter is 50 bucks geez...
Get the phone number and call the parts dept.
guaranteed much cheaper
Fram makes a filter that fits the SC that you can get at most auto parts stores for about $20.
Externally, it looks the same as the Bosch.
I bought a fuel filter for my LS at Lexus of Concord, $36, it would be almost the same if i went through Steve.
The best tool you can get for the job is a 14mm line wrench. It's just like an open end wrench, but has one more side for a better grip that won't strip the nut. The best $10 or so you ever spent.
Tim
Tim
Originally posted by nthach
It's not as good as the Bosch, the Bosch is made in Japan, while the Fram is a cheaper filter made in Israel(recently Fram is also using Chinese filters!).
But unless you can back up your claim that the Bosch fuel filter is better (or, more importantly, that the Fram fuel filter is somehow inferior enough to put bishop's SC at risk if he was to use it), then it is nothing more than conjecture on your part, isn't it?
Considering how much you brag on that "BobIsTheOilGuy" web page about how you actually try to convince perfect strangers in auto parts stores not to buy Fram filters, I am not surprised you've taken your crusade over here to ClubLexus, as well.
(off topic: i have a bit of a personal issue with Israeli products, but i won't discuss it here)
I made the mistake on my Supra of buying an aftermarket fuel filter. Turns out the thread on one end was english and not metric. An OEM filter went in much easier. I didn't make the same mistake on my SC300. My filter for the SC was $29 + a small shipping charge.
