SC400 rear camber adjustment
I have a '95 SC400 that I just took in to a get aligned after replacing a LF inner tie rod.
After they aligned it they showed me the printout and the RR camber was out of spec (before and after alignment).
They said they couldn't adjust the camber in the rear. Is this a dealer only adjustment?
there is a rear camber adjusting cam on the lower control arm.it can be adjusted with two wrenches.rear camber and toe can be adjusted on this model.i have aligned many coupes in the past 6 years of working for Lexus.
thanks cuttingedg:
the remark I got was something like " there is no rear strut adjustment for the camber"
guess I'll just get my money back and have it done at the Lexus dealer unless someone has a better idea.
