Fuel Filter
Besides completely removing the gas tank from the car? Not that I know of, just fill up before you hit the 1/4 mark, or better yet, the 1/2 mark. Also, dont just drive off after pumping the gas, go inside and buy a slurpee or sit in your car and listen to a little music; that way the stuff at the bottom that got all stirred up while pumping gas will settle down at the bottom again.
You could, that would prolly get a good deal of the crap out, but will KILL your filter. Also, there is too big of a risk of some of the stuff getting into the engine. Its a good idea and would prolly work, but I would rather going the safer route (siphoning out the gas...or something else). We need someone else to get in on this discussion
All this talk is fine, but I HATED changing mine. I would do it regularly. Gas from the line above the filter empies out all over the place and the lines are hard to get lined back up to tighten the nuts back down. Worst designed part on the car. Other Toyotas use a canister, not a bolt in inline filter.
1JZPWRD
Performance & Maintenance
14
11-01-12 04:17 PM
