Fuel Filter
Old 06-05-04, 01:18 PM
dinh626
dinh626's Avatar
Default Fuel Filter
I own a 1992 SC400 with high mileage. Would you guys recommend changing the fuel filter?
I"m doing some maintenance on the car and i ran across someone's signature stating "if you drive a high mileage sc4 change your fuel filter you'll be glad you did"
Tried searching but didn't come up with anything, so is this really important to do?
Thanks
Old 06-05-04, 01:31 PM
/Aerostar\
/Aerostar\'s Avatar
I recently made a nice thread about changing my fuel filter. Straight up, it sucks, not fun at all. But I would recommend having it changed...or if you insist on doing it yourself, get the right tools!!
Messy messy job
Old 06-06-04, 11:20 PM
PERRYinLA
PERRYinLA's Avatar
Default Misery loves company
For all the posts that say you should change it, there are an equal number of posts (some from full-time Lexus mechanics) saying it should last the life of the car.
Old 06-07-04, 01:43 PM
/Aerostar\
/Aerostar\'s Avatar
Well, its just my opinion. Better safe than sorry
Old 06-07-04, 08:47 PM
saber
saber's Avatar
Yes, but soak the fittings in rust penetrant for several days before attempting removal and use the highest quality metric wrenches and other tools. Traditionally, Toyota owners who don't change the fuel filter end up with expensive problems like partially clogged, worn or leaking fuel injectors or cold start injectors, failed fuel pressure regulators and failed fuel pumps. These problems not only affect the fuel system, but can damage / ruin expensive emission system componets as well like the EGR valve (mostly pre-'98 models), catalytic converters, etc and contribute to substandard fuel economy.
Old 06-08-04, 12:47 AM
Lexusfreak
Lexusfreak's Avatar
Thumbs up
Agreed! It's a wise maintenance item to replace.....like the saying goes, pay a little now or a lot later!
Old 06-08-04, 06:47 PM
van_es300
van_es300's Avatar
Default How much to replace it?
Old 06-08-04, 07:54 PM
/Aerostar\
/Aerostar\'s Avatar
DIY:
$25 for Bosch filter
$10(?) for some quality wrenches
$3 for minor burn relief lotion Laying in a pool of gas for an hour is not fun
And the quote I got from Toyota for changing the fuel filter on a supra was $105
BTW, if you're going to do this, for the love of god, take advantage of these tips:
- Get GOOD open end wrenches to do the job, do NOT try using some cheapo crescent wrenches
- SOAK the fittings with some WD40 or PB nut breaker stuff, again
- Disconnect the fuel pump connector and run car till it stalls
- Open the gas tank cap to relieve pressure in the tank
- And last but not least...do not do this job on a painted surface....
Have fun
Old 06-08-04, 10:25 PM
saber
saber's Avatar
Aerostar, are you saying you still had quarts of gasoline leak out of the fuel lines even though the gas cap was opened up to relieve pressure in the gas tank? I have not attempted to change the filter yet on my LS400 V8, but I have changed it several times on my Toyota truck fuel injected engine. I never had much leakage from the truck engine fuel lines after disconnecting them so the job was not too difficult or troublesome. However your experience seems to suggest there is no way to avoid major gas spillage when changing the V8 fuel filter.
Old 06-09-04, 03:32 PM
/Aerostar\
/Aerostar\'s Avatar
I did disconnect the fuel pump connector, but I did NOT take off the fuel cap . I learned that from VVT-i AFTER doing the job. I actually lost about 4 gallons of gas, but Im guessing that if I took off the cap it would have been MUCH MUCH MUCH less
Old 06-09-04, 10:15 PM
lexusondubs
dubsonlexus
lexusondubs's Avatar
i had lexus change mine in my LS 400 it was like $125 or something like that i wanted the piece of mind of knowing i had a new one after 125,000 miles ... also lexus says you do not have to change the fuel filter !!!
Old 06-10-04, 09:24 AM
VSsc400
VSsc400's Avatar
i change my fuel filter every 30k miles. I have changed it 2 times now and the 2 times that i've done it, the gas in the filter came out very dirty. I take it to a shop and they do it for about $35 and take them 15 minutes to do...
Old 06-10-04, 01:13 PM
/Aerostar\
/Aerostar\'s Avatar
Thats wierd, do you continuously let your gas gauge drop below the 1/4 mark?? My filter was the original (109,xxx miles) and it was dirty, but not THAT bad
Old 06-10-04, 01:15 PM
VSsc400
VSsc400's Avatar
i usually fill up about 18+gallons, way below the 1/4 tank line.
Old 06-10-04, 01:39 PM
/Aerostar\
/Aerostar\'s Avatar
Oooooooh, well there's your problem. Your fuel pump is sucking up all that crap on the bottom of the tank and clogging up the fuel filter.
Quick Reply: Fuel Filter
