blown trans in 99 rx300
Super Moderator
XYZLexus1,
Before I had my fluid flushed out last December, the fluid had turned silvery or pinkish, not clear or red. Is the silvery stuff that clutch material, as I was always told it was.
I would say yes, what else could it be? The housing is aluminuim, it is not dissolving, the seals are black HNBR rubber. My past experience has always been when I changed the transmission fluid often (every 30K miles) the transmission would slip and need rebuilt after 80 to 100K miles. The cars I changed transmission fluid only once or every 75K would last until I sold the car or about 150 to 175K.
Remember a transmission is not an internal combustion engine that contaminants the oil with the byproducts of combustion, it is a closed unit for all practical purposes like the differential in your car.
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
I've been doing complete transmission drain & refills now since that flushing machine has been on the market & have never had so much as a transmission slip in any of my vehicles (although this is my first Lexus), & have never paid a dime for any transmission repairs. An engine & transmission (with proper maintenance & not abused) should last the entire life of the car regardless of milage without any significant problems. I have not seen anywhere in the Lexus manual that states to NEVER do a complete fluid drain & refill and over half of the Lexus dealers that I know of in Ontario actually have that complete flushing machine.
Look in your owner manual, it states the transmission fluid does not need changed until 100K. Lexus dealers have flushing machines? no kidding, they are in the business to take your money. You change your transmission fluid often and you will be rebuilding. I believe the Toyata Type 4 is synthetic, due to the fact it states excellent cold weather performance, a characteristic of synthetic fluid and do to the price. When your car shifts gears the clutch engages. Friction must exist for the clutches to work. Friction comes from the clutch material which has a finite life due to the limited thickness of the clutch pad and the fluid. New fluid without the expended clutch material has less friction than aged fluid with clutch material. Therefore your shift duration is longer, yet smoother because the clutch is slipping more and wearing itself out. The majority of transmission issues will occur within 3000 miles of changing the transmission fluid.
The only issue with not changing your fluid is the passages in the transmission can become plugged with the expended clutch material. This however would take well over 100K and probably will never occur.
Take my advice whenver any dealer, especially Lexus, BMW etc give advice do the exact opposite and you will be right 99% of the time.
When you change your tranny fluid, it is a good idea to recheck the fluid level a day later. Since you use the dipstick opening to get the fluid in, it's hard to measure accurately at the time of fluid change. So, In the morning of the next day, start your engine and let it run for a minute then recheck the the tranny fluid level. It should fall between the low and high marks on both sides of the stick.
When I changed my fluid at 30k miles, I measured the fluid level right after the fluid change several times and it seemed to be at a correct level. However, my tranny seemed to act weird after that. When I floored my car, the gears changed really fast. It jumped from first to second to third to fourth gear at around 40mph and as a result I didn't have a strong launch. I rechecked the tranny fluid level 10k miles later and found out that the level was way too low. Luckily I've found this out before blowing my tranny.
It is a good idea to check all your fluids levels and have a look at your engine every 2 weeks if not every week. It only takes 5 minutes but may save you thousands of dollars.
Frequent draining and refilling of the tranmssion fluid pan (about every 15,000 miles) is optimal for all Toyota / Lexus automatics and costs almost nothing ($7.50 for 2 quarts of Type T-IV fluid http://www.saber.net/~monarch/typet.jpg). 30 years ago, in fact, all Toyota owners manuals recommended this drain and refill service every 18,000 miles.
Same deal with the power steering fluid. No fluid replacement interval is listed in USA Toyota / Lexus owners manual and literally thousands of LS400 power steering pumps / racks / high pressure hoses have needed replacement after 10 years / 100,000 miles because the owners never changed the fluid or cleaned the filter screens located in the solenoid control valve and pump fluid reservoir.
Yes, a bi-weekly look over is a good idea. I do it twice a month (on the 1st and the 15th) so I don't forget.
I also check my oil level immediately after every oil change.
Super Moderator
Take a look at your fluid when the engine as cold, and again when it is hot and look at the level.
You can get really funny readings just the same with your coolant levels on cold and hot.
Originally posted by m015778
Hi, my wife has a 99 rx300 and basically drives the car to take the kids to and from school, she doesn't work and has never towed anything. Her trans is blown with 76,200 miles on the car and this totally blows my mind that this happens on a Lexus that prides itself on quality!! I did not purchase the extended warranty when i bought the used car but the manual says that the engine and trans are covered till 75000 miles. My wife had the trans fluid changed at 75000 miles and corrected the trans from slipping for about 3 months until now and the car now has 76,200 miles, over the warranty by 1200 miles. Can anybody give me advice on how to rectify the problem without me paying out thousands of dollars to fix a "quality luxury car"? I also own a BMW and a MB and have never had this problem occur? If Lexus brags about its quality vehicles, how can this happen?
Not to sound like a Monday morning quarterback, but perhaps you should take it to Lexus first when the tranny was slipping. It would've been covered under warranty.
Also, Lexus tranny requires Toyota Type IV fluid. Some rough shops put cheap Dexron IIe in every car. They don't bother with Chrysler or Toyota fluid. This might explain why your tranny blew shortly after the service. How the previous owner drove the vehicle is also a factor.
