? For thoose with the Optima bat?
I finally found the 35 reversed. They do not call it R35 online. weird
Optima R34 --$120
Cranking Amps- 980
Cold Cranking Amps- 800
Reserve- 110
Dimensions are 10"x 6.8"x 7.8"
Weight is approx. 38.8 lbs.
Battery has Top Post only (Reversed Terminals) with handle for easy installation
Warranty.....36 Months Free Replacement and 72 Months pro-rated
http://www.optimabatteries.com/products/pdf/R34.pdf
Group 35 Red Top --$100
Cranking Amps- 910
Cold Cranking Amps- 720
Reserve- 90
Dimensions are 9.4"x 6.7"x 7.6"
Weight is approx. 33.5 lbs.
Battery has Top Post (Reversed) and handle for easy installation
For the extra $20 I will take the more CCA, CA and reserve.
Optima R34 --$120
Cranking Amps- 980
Reserve- 110
Cranking Amps- 910
Reserve- 90
Wald GS
GS - 1st Gen (1993-1997)
01-29-03 09:13 AM
