Oil Capacity 93 ES300
Ok, I searched all over and could not find this in a definiti measurement. What is the oill capacity for a 93 ES300. What does it say int he owners manual ? I just got my 93 and need to change the oil.
Thanks in advance.
Thanks in advance.
Is that straight from the manual? I put in 5 quarts with a new Toy filter and the level was too high. I called a local auto part store and they said 4.3 Quarts. I called the lexus dealer and they said 5.5 Quarts. Well if 5 Quarts is high, I can imagine that there are a lot of es300's with leaking gaskets and such from the dealer. I ended up draining out a half Quart and the level was good after that. That's why I was so curious as to what the owners manual called for.
Thanks
Thanks
The dealer just changed my oil and it was over the full mark on my dipstick. I brought the car back to them and they had to drain about ½ Quart so it was right at the full mark. He told me that the car ('03ES) called for 5 quarts that are metered in by a supposedly accurate machine, so even though your car also calls for 5 quarts w/filter, I don't know why this happens.
That's kind of sad that the lexus dealer doesn't even know what the exact capacity on these cars are? Mine is just righ with 4.5 quarts so that's what I'll be putting in next time I do the change as well.
Thanks
Thanks
If you do not have a published oil capacity and you know that the car has the correct dipstick that has not been replaced, then the best way to ensure the correct oil level is to SLOWLY refill the crankcase, quart by quart, give each quart time to settle, take a reading, stop at the full line, and then add a small amount to account for the filter capacity. Start the engine, watch for the red light to go out or the pressure gauge to come up, check for leaks, then cut the engine off, give the oil a couple minutes to settle, and take another reading. If the oil passages are not clogged up, it should be pretty close to the full mark.
Sometimes you have to look carefully, though.....clean oil can be very hard to see on the dipstick.
