AC compressor replaced, system charged, AC light still flashing..now what?!
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
A few weeks ago my AC compressor locked up on me so tonight I got around to replacing it with a reman. I put the compressor on, charged the system with refrigerant and I'm still getting the same results. When I turn the AC on, it will kick on for about 2 seconds, start to blow cold air, then the compressor kicks off and the AC light flashes. What do I do??? Are there any fuses I need to pull or any ECUs I need to reset? I did the climate control diagnostics and only got a Code 21 (Solar sensor) because its dark outside.
This black car with leather in August is killing me..ALMOST as much as the $400 I just spent only to still not have A/C is killing me. What do I do guys?
Thanks in advance!
Thanks in advance!
my ac light flashed when my compressor wasn't working right ... had it replaced and now its working fine...
did you remember to put in the ac/compressor oil?
chrisindub
Performance & Maintenance
35
07-08-12 03:35 PM
hazepurple
11-27-11 07:48 PM
