Question about the K and N Air filter.
Keeper of the light
Can i use anything else to re-oil it aside of Kand N oil? I cleaned mine and ended up not being able to find my oil.
The stores are closed currently and i would like to drive it, but not without oiling it somehow.
You must re-oil your K & N air filter with K & N oil & NOTHING else. You might want to buy a paper filter as a back up in case something like this happens again.
That sounds like something K&N would say.
Before there even was a K&N, there were foam filters that could be re-oiled with any light machine oil. So in a pinch something like 3-in-1 would work. I even used motor oil once and it worked fine, but that was because I could wring the excess oil out of the foam- you can't do that with a K&N.
Just like with K&N oil, it's better to use too little than too much, but I'm sure you already know that, B!
Well that what they do say! I wouldn't suggest anything else that might possibly damage another members car now would I?
If you have done it with light machine oil, great! but I haven't so that why I said to use only K & N filter oil. I always excercise on the side of caution & there is nothing as uncommon as common sense!
![Embarrassment](https://www.clublexus.com/forums/images/smilies/redface.gif)
So, using your logic, we should only be doing the things you do, and if you have not done something, we shouldn't, either?
This is all a moot point by now- the stores are now open so Brian can buy whatever he wants.
Keeper of the light
True, i do have the kit now. I actually took the bimmer to get a fram filter while i posted this because i really would have rather had my K&N in the vehicle. Unfortunately walmart carries the fram, but not the K&N fluid, so i knew ahead of time that i was only going to be able to leave with the stock filter until the morning came.
no I'm not saying everyone should do as I do.....he was in a bind at the time & wanted suggestions, that was the best one(s) I could come up with.........all I was saying that personally I wouldn't use anything other than the K & N oil if I was in the same situation......so I wasen't about to suggest something esle I didn't have knowledge about for risking damage to his car. that's all.....
ThePill
18
05-25-08 11:58 AM
