Engine noise continue for 30 sec after key was pulled
Loud engine noise continue after key was pulled
Desperately need help!!
Yesterday, I drove my 99 RX300AWD (odo=110K miles) for 20 Miles with A/C off.
Then, I parked the car for 2 hours.
When I started the engine, there was a loud noise along with engine noise (sort of crane noise)
Then, I shut the ignition off & pulled the key, engine shut off.
However, that strange noise continue for approx 30 second (enough time for me to open the hood and trunk trying to get a wrench)
Then, the noise completely gone by itself.
I started the engine again & no more noise. I tried several times, and couldn't repeat the problem.
Later, I drove the car for 100 miles, with a/c on & off. Nothing unusual.
Trans oil&Engine oil level is fine.
Could it be the starter keep engaging to the flywheel, or starter relay? If yes, why the noise continued for 30 sec after the key was pulled?
Appreciate any suggestion.
Email: mek88@yahoo.com
Los Angeles
Los Angeles
I had a starter get stuck on in my SSEi. It wasn't engaged in the flywheel but it was constantly spinning a high rate of speed. Sounded like an electric whine at a very high rpm, almost like it was going to explode. Continued even after shutting down and removing the keep. Had to disconnect the battery to get it to stop.
I bet you that is what you got.
steviej
steviej
Stevej,
Thanks for the reply.
So, what was the problem on your SSEI?
I will try the relay tomorrow.
mek88@yahoo.com
steviej
mek88@yahoo.com
steviej
ichitaka86
NX - 1st Gen (2015-2021)
14
09-19-20 05:55 AM
