tranny fluid check
okay, I think i over filled. The manual says 3.5 quarts. I drained and filled 3.5 and it was too much so I emptied some more out. It still seems like too much. It is about 1/2 cm over the high mark. Engine idling, went through all the gears before checking. Should I empty more? I already emptied .70 quarts.
Some old tranny fluid will stay in the torque converter and not drain out, which is why you overfilled. You'll have to keep draining until you reach the correct level on the stick.
A trick some mechanics use is to measure the amount of tranny fluid drained, then put in new fluid equal to the amount. Do that next time.
SuperCoupe400
Performance & Maintenance
05-09-08 08:07 PM
