Help w/ Homelink
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
I need help with my Homelink system in the GS400. I don't have a car manual therefore I don't know to reprogram the Homelink system within the car. Can anyone help me with this problem please? Thanx...
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
From my '98 GS400 Manual
1. Decide which one of the 3 buttons you want to program. Push and hold down the button until the indicator light begins to flash. While holding the button, follow steps 2 and 3.
2. Bring the hand held garage door opener within about an inch of the button being programmed and push the button on the handheld remote garage door opener. The signal from the hand held garage door opener is sent to the vehicle's opener.
3. When the frequency and code is registered, the indicator light flashes rapidly. At this point, you can release both buttons.
4. To program the remaining buttons, repeat steps 1-3.
If you want to write a new program over the program set already, select a button and repeat the procedure from step 1. The previous program is erased and a new program is set.
If the transmitter has a "rolling code" feature, it is necessary to program the in-garage receiver, after programming the garage door opener in the vehicle. For setting the in-garage receiver, refer to the instruction manual for the receiver.
After setting the in-garage receiver, push the programming button on the vehicle for about 1 to 2 seconds within the operational range.
Garage door openers manufactured before 1982 cannot be programmed.
To erase the garage door opener memory push and hold down the 2 outside buttons until the indicator light flashes. All memorized data will be erased.
Hope that helps.
Hope that helps.
turbotuner
06-15-10 06:48 AM
