GS400 Transmission Fluid Capacity?
If you just drain and fill, then you'll need only 2 qts of Type-T trans fluid. Its around $5-7.00 per quart.
If you want to do a complete trans flush with the machine the hook up the trans cooler lines, then you will need about 14 qts.
i bought 2 wasnt enough then i bought 1 more and used about half of it.. the thing is tranny fluid is in ur torque convertor too so some of that runs out as well... you can never get an exact amount for just a tranny fluid change.
my .02 cents
my .02 cents
1999, 400, automatic, capacities, capacity, change, drain, fluid, gs, gs400, lexus, oil, refil, trabsmission, transmission
