93 GS300 is throwing codes #24 & #31
Look like you got a bad air flow meter because code 24 is intake air temp. sensor and code 31 is volume air flow meter circuit malfunction. Both codes relate to air flow meter.
Replacing air flow meter is just a start point, because your car may have another hiding problem. Such as EGR tube clogge up( every well know for the GS300).
The airflow meter can be expensive. If you think it's bad, why don't you try cleaning it by spraying electronic contact cleaner? If you have an aftermarket air filter, sometimes the oil coats the meter and messes it up. Worth a try.
