Timing chain???
I have changed mine, and it takes an air compressor, impact wrench, breaker bar, 10mm, 12mm, 13mm, 14mm, 22mm sockets, a set of allen wrenches, and some extensions. A set of manuals is a MUST. It should take at least 2 hours the first time. After that, you will have hated it so much that you could do it again all over again in 30 minutes because you remembered the experience so vividly.
