quick SC300 O2 Sensor writeup
Old 10-26-04, 10:27 PM
mteele
mteele's Avatar
Well, I bought the car used, so I am not sure how recently some things have been changed, specificaly the O2s in the manifold.
But I do know my O2 in the cat is GONE, and that my gas mileage sucks (240 miles to the tank). I'm about to do some exhaust work, so I would like to get everything done at the same time. Which is why I am starting to wonder if my cats are due for replacement (184k miles on the car)
Old 04-25-06, 11:34 AM
simonsays
simonsays's Avatar
everyone, sorry for bringing up old threads, but i bought the bosch universal O2 sensor.
i was gonna try to install it on yesterday, the problem is, on my O2 sensor ports, there's two screws that hold the sensor, now a nut thats on the sensor. my car is a 92 sc300. i also found out that NAPA or autozone doesnt carry universal O2 sensors for the sensor before the cat. only for the one after the cat. does anybody else have a problem like this?
Old 04-26-06, 06:46 AM
Tammy
Tammy's Avatar
"DENSO" is the toyota brand. The Bosch may not match the value the computer requires. Previous posts have reflected this.
Old 08-06-06, 04:53 PM
toykilla
toykilla's Avatar
I have the same problem.
Old 08-17-06, 02:06 PM
SC4-94
SC4-94's Avatar
Default Question on O2 sensors
I have a 92 SC300 that I plan to replace the O2 sensors With Densos(direct fit). Do you disconnect the negative batt. cable anytime you change emission parts or was that to clear a CEL?
Old 08-20-06, 06:13 AM
Tammy
Tammy's Avatar
Yes, it is best and safer to disconnect the battery prior to disconnecting any sensor ..
Failing to do so may cause a failure to the engine Electronic Control modual (ECM). Is energized by the battery
Old 08-21-06, 12:33 PM
martshap
martshap's Avatar
Quick question: Which O2 sensor is "bank 1, sensor 1" on the 1996 SC 300?
Is it the sensor that dude took off in the pcitures above (i.e. on the exhaust manifold)?
Thanks!
Old 05-08-10, 12:02 AM
djrazr
djrazr's Avatar
Thanks!
Closest one to the front i hear. I need to change mine. I assume it's the one in the OP's pic
Old 01-21-11, 04:41 PM
Devor
Devor's Avatar
I just got back from the smog station and failed =( I was told I need a new cat i have 190k on the car and will most likely need new O2 sensors. anywho I ordered the new cats and was wondering where the rear o2 sensor is? I was told there are 2 one located next to the intake manifold and 1 located by the cat... I was wondering if I need to get a new one for the rear when I get the cat installed or can I do it another time? in other words when I go to get the new cats installed do I HAVE to replace the o2 while im doing the swap?
Old 01-21-11, 06:51 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
you don't need to have the O2 sensors replaced so long as they are working properly...
What part of the emissions did you fail on? Do you have the numbers?
Too rich, too lean or misfires can cause an emissions failure as well...
Old 01-24-11, 12:02 PM
Devor
Devor's Avatar
let me get the write up from my house Ill show exactly what the numbers were. I changed the plugs and wires as well as the air filter and the distributor cap and rotor but it didnt pass. So im hoping to change any sensors if I can(cheaper then the cats)change the sensors and not have to swap out new cats right now that would be nice to save a few bucks in order to pass smog
Old 01-25-11, 08:57 PM
davekuhar
davekuhar's Avatar
I found the o2 sensors online NEW $19.99 free shipping and handling. They work fine so far.
Old 03-30-11, 12:45 PM
BobbyB
BobbyB's Avatar
Default 02 sensor
Can you tell me where you found them on line for $20...?
Are these the universal, or the standard..?
Old 06-16-12, 05:43 AM
wickedtaco
wickedtaco's Avatar
Default sensors
where bouts did you find the sensors? I'm in need.
Old 06-20-12, 08:13 AM
davekuhar
davekuhar's Avatar
I found them on ebay!! and they are universal, they do work!!
Dave
Quick Reply: quick SC300 O2 Sensor writeup
