Idler Pulley Bearings w Timing Belt Change?
More for the pro-mechanics:
I see that there are bearing kits available for the left & right idler pulleys for a 94 LS.
They are cheaper than a whole new pulley but not by as much as one would think. Is this worthwhile?
Does anyone have experience or thoughts with this?
damon
damon
Yes. I drove the LFA.
Is this to say that the bearing are rebuildable? Ive dont more t-belt changes than i can count, and each time ive replaced the idler bearings with the standard toyota parts. Ive never heard of a "kit"... do you have any more information as to how that works? It may not be worth the time to "rebuild" the bearings with "kits"... or maybe i just dont fully understand the concept you're talking about.
Bearings
RTCamaroSS,
Thanks for the reply. I searched some of your post concerning another matter3 days before asking this question , so I'm glad that you jumped in. This question was directed at techs such as yourself.
I would not be very familiar with TB idler pulleys. Aren't bearings the only wear part?
Strangely 2 different mfg's make replacement idler bearings:
Koyo: Lower Left Idler Bearing A5300-63071
NSK: Right Idler Bearing A5300-57566
I have no idea what these numbers mean or what they translate to. ( Or if they are translatable!!)
I'm in Dallas & Jason Pham of JP Importz ( 3 miles from me! ) sent me a reply saying that replacement bearings are available from Toyota.
My thought was to pool available knowledge & source these bearings direct & avoid the hefty mark-up.
www.bearingsdirect.com
My name is Mark Conner & I have no direct investment in the pre-mentioned "linked" company & I do approve this message!!
Originally posted by hyperopt
First generation LS uses Koyo and NSK bearings as OEM. If I remember correctly, it is easy to replace just the bearings on those idlers. How much are the bearing kits?
Koyo A5300-63071 Left Bearing $32.75
NSK A-5300-57566 Right Bearing $75.00
That is sourced as an auto part. I think that it would be much cheaper if we could properly identify the bearing & cut out the middle-man.
Do these #'s mean anything in the bearing world?
HEy damon... thats my name as well...lol
Funny thing too..My water pump seized snapping my timing belt. I just replaced my water pump, idlers, timing belt and had ac belt changed along with a vaccuum line.
Funny u brought this up because i told my mechanic to use oem...
