How much fluid needed for coolant drain-and-refill? (LS400)
How much coolant is needed for radiator drain-and-refill on a 1st gen LS400?
The owner's manual only lists a total capacity of 11.2 quarts.
A very good tip I read here was to use & shop vac on output mode to force the coolant mix out of the block.
I had a hose feeding water in thru the radiator as I flushed the system so I knew that I had cycled out the old. But my first attempt at getting a 50/50 mixture back in was not succesfull due to the amount of coolant retained in the engine block.
If you try this just from draining & refilling at the radiator , you will have limited success & dangerous implications
damon.
damon.
Elless400
12
05-01-17 09:16 PM
