removing crankshaft pully
Old 11-15-04, 09:15 PM
eericn
eericn's Avatar
Default removing crankshaft pully
my car is a 92 sc300 5sp. My first question is why can I turn the crank shaft while my car is in gear and the rear wheels are on the ground? Second how have people removed the the pully mounting bolt on the crankshaft pulley? Any ideas?
ethan
Old 11-15-04, 09:23 PM
RTIS250
Yes. I drove the LFA.
RTIS250's Avatar
Default Re: removing crankshaft pully
ethan
clutch slipping maybe? depending on how much torque you're putting on the bolt, it can slip. as far as removing the pulley bolt, there are a few different ways to do it. i have an air impact gun at work powerful enough to remove it. or, if you dont have access to that, you can use a chain wrench to hold the crank pulley (with a peice of scrap belt wrapped around the pulley to protect it), and a breaker bar with a pipe on the end of it on the crank bolt itself. by hand, they are fairly difficult to remove, but it can certainly be done. there are other methods that i wouldnt recommend, that involve using the starter to break it loose, but i dont recommend that.
Old 11-16-04, 02:54 PM
eericn
eericn's Avatar
Ok I got the Bolt out but am having difficulties removing the pulley itself. None of the bolts that I have seem to fit the bolt holes in the pulley, the closest is a 8mm 1.25. Does any one know the actual size of these holes?
ethan
Old 11-16-04, 06:04 PM
RTIS250
RTIS250's Avatar
ethan
i have a puller in my box at work, i will try to check the thread pitch on the bolts for you tomarrow.
bwils
11-21-22 05:04 PM
ef9
Performance & Maintenance
07-29-18 05:33 PM
jwynn
SC- 1st Gen (1992-2000)
07-24-15 06:30 AM
Lexus082
05-06-14 01:15 PM
TumblerZ30
03-02-10 06:29 AM
Quick Reply: removing crankshaft pully
