where the hell has my tranny fluid gone???
Dysfunctional Veteran
ok, this is crazy, but my ATX Dipstick reads bone dry. JPI Just serviced it yesterday, and Jason noticed the dipstick had no fluid, so he added about 1 qt. and poof! there ti was, at the warm level.
i drove it home, maybe an hour, and i check it when i arrive...no fluid on the stick...WHAT THE HELL IS GOING ON? to make matters worse, there si no ATF on the ground in front of my house (only oil) and the car drives incredible. the shifts arent clunky, there is no slip...where the hell has the fluid gone? is this a toyota thing?
yeah i had a drain and fill done at a speedy lube rigth after i got it. it was BLACk when they refilled it, and pretty badly burnt this time around when JPI did it, but an update:
i found my trans fluid this morning, in the trans, where it belongs. there is no leak. i just didnt shift it through the gears (Started and let idle in P when i checked). i checked this morning vbefore i even started the car, and its at the top of the "COLD" line. all is well.
ok? lol, there is fluid in there, all the way up to the top of the "hot line, if i check it when the cr is running, i wouldnt even worry abotu it man. thanks though. the car has been running great for the past few days, so im happy.
transmission level and type
Hello Everyone what is the best atf fliud to use for a 96 es300!? And one more question when i check the fluid where should the line be!? thanks for your help.
SuperCoupe400
Performance & Maintenance
05-09-08 08:07 PM
