Sc trouble need help
Check engine light came on it says that it is radom miss fireing on cylinder 1 and 6.. it happened after i did the timing belt and water pump and the cap and rotor..So i decided to change new wires and plugs, disturbutor, and injectors. The injectors were change on 1 and6.. timing was correct.. the rotor is sitting on tds..everything has been double checked..All parts was bought from Lexus..what do you guys think the problem could be... Do you think it could be the O2 cencors???????
