Water pump
I am about to do a tune up and was wondering if any of you have used the water pump on Ebay for $60? If not where did u get yours and how much did it run you? Does anybody have a part number or price and place to buy the power steering rebuild kit? Mine isn't leaking but trying to knock as much stuff out while I'm in there? Any thing else I should be Especially aware of while I'm in there( YES I searched) But suggestions would be helpful.
every computer system at all the auto parts stores show 2 listings for a water pump for the SC. when i changed mine, I had to remove it first and match it with the correct one.. both water pumps almost look identical although the part numbers are different, so be careful if you decide to match it up.... I got mine from my brother's auto parts store.. one of the 2 part numbers ran for about 50 bucks.. the other was a hundred.. mine took the hundred dollar one.. so I guess there's 2 water pumps for the sc.. just make sure that you get the right one...
Yup. Well for the SC3 there are 2 types. The one we need is the same one found in the Supra Non-turbo. It runs about $100-$140. For some reason, the pump for the Supra TT is the one you'll find a lot cheaper. Thye look exactly the same except for one little flange and a couple more openings.
