No start
Had to jump the car after it sat a few days. Took it to a local shop for a starting/charging system diagnostic. They indicated it needed a new battery and alternator. I have a new battery and will take it in to have the alternator replaced - but now I can't start the car with a jump. I get lights, then one click, then nothing. Same as before.
Put the new battery in, same no start.
Wouldn't the car start if just the alternator is bad?
I think your starter is bad. When mine was bad, the car clicked once and I could hear a very faint whirring/buzzing sound. I just re-built my starter and it worked fine.
Sound like you got a bad starter. If this happened again, try to tap the starter by using a long piece of wood and hammer it on the starter and then try to start the car up again. The 99 ES is easy enough to get to the starter.
Originally Posted by jimbo22s
Is the starter right next to the battery and air filter housing? Does it say 'Denso 12V' and '1F'?
poplady
Maintenance
06-16-14 05:12 AM
Kalogerus
Performance & Maintenance
14
02-04-12 02:05 PM
