Part# for Oil Filter GS300
Originally Posted by mikal
also, this filter fits GS300's I6 right?
Toyota Part Number 90915-YZZD3
http://cgi.ebay.com/ebaymotors/ws/eB...919887693&rd=1
Thinking of getting a case of this.
If you could find the 90915-20004 filter I would buy quite a few. Check Carson Toyota, they still had a few in stock a couple months ago. Otherwise the YZZD3 is fine too.
1 Post
People are we really going to if the motor is going to know what filter is on there or not . Just wanted to know like I said before please tell me what all the hype is on the filter What filter does the dealer give us when we get the oil changed at the dealer? Just wnat to know if the K&N filter is not the way to go. OIL change @ dealer $40.00 doing it your self $35.00 (K&N filter) $10.00 (MOBIL 1) 6 pack $25.00 TIME PRICELESS!!!!!!!!!!!!!!!!!!!!!!!!!!!
Originally Posted by Neo
Unless someone else speaks up, you may unfortunately be the first to try it on the GS.
The One
Originally Posted by GammaLex
If it does thread on and seal properly is there any chance of messing something up? Oil not going in aand out fast enough burning up the engine?
The One
It fits So far I put 6 quarts, im waiting till tomorrow morning since I have driven it to check if it needs more oil.
Does anyone find the dipstick on the GS300 kind of hard to read? It doesn't have the cris-crosses on it like most other dipsticks have to "hold" onto the oil.
Also, I'm going to be changing my own oil for the first time. Do I need to remove the underside splash guard to get to the drain plug? Does anyone know the exact size of the drain bolt? And it seems like the oil filter can be accessed clearly from above the engine bay, unlike the GS4 where it's below. Is this true?
The One
As for the bolt, going from memory, I believe it is 14mm. The filter can be kind of seen from above but I've always gotten it out from below. The car is already jacked up so ...
Good luck.
so what's the verdict. is the only TRD one to use the huge one Gamma used or is there a medium one too like mikal mentions?
Is the K&N any better than the current 90915-YZZD3 oem? I change every 3k at most and have always used oem.
btw-do V-8 and I6 use same filter?
edit-this place seams to have the old one ??
http://www.drivewire.com/toyotaparts...oilfilter.html
Why bother with Toyota? I always use WIX filters and like them...
Part number 51348
On www.fleetfilter.com, they have the 51348 listed for $2.72.
Part number 51348
Part number 51348
Part number 51348
