New Prestone coolant
New Prestone coolant safe?
Anybody have information or experience with some new Prestone coolant I saw at K-mart the other day. The label states New Formula which is safe to use/mix with ALL coolant of any color from any manufacturer.
Can Prestone be trusted? Look at what the old bottles of Prestone claimed:
- Nothing Protects Better Against Rust and Corrosion
- Protects Aluminum and all other engine metals
- Trusted Quality since 1927
Well here's what has happened to Toyota owners who have trusted Prestone in the past:
http://www.saber.net/~monarch/radprest.jpg
And here's what has happened to Toyota owners who have always trusted the Toyota engineers:
http://www.saber.net/~monarch/rad89.jpg
http://www.saber.net/~monarch/radtoyred.jpg
My advice: Save Prestone for your 1984 Ford, and use Genuine Toyota coolant and DISTILLED water on your Lexus
prestone Dexcool
Is the prestone Dexcool antifreeze the same as the red coolant used in all Toyota/ Lexus vehicles? I don't know if I trust the new prestone coolant that they say works for all models. I bought some Prestone Dexcool today and it says that it is used for Ford and Chrysler vehicles. Is this the same stuff that Toyota uses?
I switched over to regular antifreeze many years ago and have always used distiled water. Car runs fine. Drain and fill yearly and no sludge or leaks. Will be changing timing belt soon, so I'll take a look at the water pump at that time. But my general understanding is that regular antifreeze has copious amounts of silica and phosphates, while the Japanese stuff only has tons of phosphates and that Dex-cool stuff is organic phosphates with neither of the silica or phosphates. What is the new Prestone stuff? Is the new Prestone more like the Japanese coolant or is it more a Dex-cool formula that won't gum up when mixed?
Dexcool antifreezes are better than Prestone Green because they don't have nasty borates that can pit and erode aluminum or silicates that abrade the water pump seal and plug radiator core tubes. But Dexcool antifreezes can turn into a terrible sludge like goo called "dealthcool sludge" if the cooling system is contaminated by air past a weak radiator cap or missing cap on the coolant overflow jar:
http://www.saber.net/~monarch/deathcool.jpg
http://www.saber.net/~monarch/deathcool1.jpg
http://www.saber.net/~monarch/deathcool3.jpg
GM even made a Videotape for technicians describing the problem:
http://www.saber.net/~monarch/deathcoolVideo.jpg
Bottom line: The Toyota Red is chemically unique and provides perfect protection of Toyota cooling systems. No antifreeze in an auto parts store is chemically identical to Toyota Red.
Originally Posted by HarrierAWD
Would Prestone pay for a new radiator if it fails? I doubt it. There are several formulations of coolant out there for good reasons. Use only genuine Toyota coolant in your Lexus.
