did i get a fair price for 100k service?
Old 01-10-05, 12:52 PM
Cannonbear
Cannonbear's Avatar
Default did i get a fair price for 100k service?
was wondering if i got a fair price for timing belt, Acc belt, water pump, spark plugs, replace coolant, fuel filter, quoted price $1,477.89. That sound about right?
Old 01-10-05, 01:11 PM
PERRYinLA
PERRYinLA's Avatar
Depends- it that quote from a dealer?
Old 01-10-05, 01:13 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
You realllllllllly dont need to change that fuel filter.
Old 01-10-05, 01:21 PM
Cannonbear
Cannonbear's Avatar
the quote's from a family recommended shop. yeah he kind of just threw in the fuel filter , i know that one doesn't really need to change it. the dealership wanted 1900 i believe which in itself the deal i got is a bargain, but was just wondered if it was about right. parts were around 450+ labor was 900+.(quote)
Old 01-10-05, 02:45 PM
RalAegidius
RalAegidius's Avatar
IIRC, my 100K service was approximately $1,000. That was done by an independent shop that has a labor charge of $100/hr. (which is typical around here). It was folded into some other services:
$562.50 - REPLACE TIMING BELT & WATER PUMP
$425.00 - MAJOR SERVICE AS PER ATTACHED SHEET
Old 01-10-05, 03:29 PM
VVT-i
VVT-i's Avatar
The Chilton's manual called for 5 hrs labor for the Timing Belt and Water Pump, plus front crank seal( you can't replace the Cam seals on the GS400 without remvoving the Cam shafts).
Coolant will need to be drain if you do the Water Pump.
Spark plugs is 1.5 hrs labor.
Fuel filter is inside the gas tank and it's a lifetime filter.
Ask him to do just these items.
Old 01-14-05, 01:27 AM
ILOVEGIRLS
ILOVEGIRLS's Avatar
where did you get your repair manuel at? i want to change out my fuel filter.
Old 01-14-05, 02:02 PM
hyperopt
hyperopt's Avatar
I bought those OEM parts for my LS at about half of $450 so it sound like a 100% markup on parts.
Old 01-19-05, 06:20 AM
VSsc400
VSsc400's Avatar
90k mile service as stated by lexus USA to be performed with labor and parts as stated in the owner's manual and lexus service book for 99RX300 AWD is $1400. Prices may vary by dealers but the set price (MSRP i guess you can call it) from lexus USA is $1400.
I called lexus USA to ask them because I didn't want to get ripped. They told me $1400.
so if you get a price less than that; awesome
if they try to charge you more then i would go somewhere else.
pchiu408
06-03-09 01:42 PM
xfactor70
05-18-09 05:17 PM
talltrini1
Maintenance
12-31-08 09:04 AM
BlackoutGS
Maintenance
07-09-07 06:48 PM
myfirstrx
Maintenance
06-18-03 02:42 PM
Quick Reply: did i get a fair price for 100k service?
