Fluid amounts for drain-and-refill on '90-'94 LS400?
![Wink](https://www.clublexus.com/forums/images/icons/icon12.gif)
Originally Posted by CUMan
I would think that the need for a radiator flush would depend upon how the cooling system was maintained in the past. If the coolant has not been replaced on a regular basis, or if the present coolant was mixed using mineral-laden water, a flush would probably remove some of the crud which a simple drain would not remove.
However, if the cooling system has been maintained regularly, I think a drain and fill would be adequate.
Always use distilled or demineralized water when mixing the coolant.
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
kyk007
03-13-15 09:29 PM
