What is the average expected life of head gaskets?
For a 1992 ES 300 I had my head gaskets replaced around 110,000 miles. 3 years and 30,000 miles later the dealership says I need to replace my head gaskets again.
I already know that standard Lexus warranty is 1 year/unlimited milage for this service. I know my car is already pretty old, but is this something that I shoudl be reparing every 3 years?
How much life should I expect from replaced head gaskets? 5 years? 10 years?
Thanks!
Thanks!
Normally, head gasket should last as long as the engine itself unless the mating surface is pitted or warpped, improper torqued head bolts, inferior gasket material, overheated engine, or unmaintained cooling system.
Why did the tech said you needed new head gasket?
The factory original head gaskets are capable of lasting 30-50 years / unlimited miles IF - and that is a HUGE IF - the owner performs preventive maintenance on the cooling system and all other engine systems in a timely manner using factory original parts and coolant. This preventive maintenance stops cooling system corrosion and potential overheating that will shorten the life of the head gasket. .
Unfortunately, the vast majority of owners won't do this and even some Toyota / Lexus dealers may substitute a more profitable aftermarket antifreeze in place of the more expensive genuine Toyota coolant or they may fail to use distilled water in the cooling system. The end result is unpredictable head gasket life. Replacement head gaskets are often less reliable / durable than the factory original ones for a variety of reasons
What can you do? Next time either buy a brand new Toyota / Lexus and maintain it in factory original mechanical condition or buy a used, one-owner Toyota / Lexus that has been maintained in factory original mechanical condition. Since the vast majority of used car shoppers buy on price instead of on service records, they often become entrapped in a revolving circle of automotive poverty.
Why is the dealer telling you you need new head gaskets?
Is compresison low?
Burning oil or losing coolant?
Things like this, you may want to consider a new vehicle as the treadmill of expense will continue to increase.
o.k. guys.. sorry to bring this post up from the dead... i am guessing i have a Blown Head Gasket.. i been refilling my coolen reseriver for about a month now.. but the oil doesn't look like bad or anything.. and the car over heated twice before.. anyways.. i just wanted to know how much would a local shop charge to change the head Gasket?? and since i'm changing the head gasket. what else should i consider changing ?? also. would it be worth it to change the head gasket or should i just junk my 93 es (got it for 3000bucks).. or put a JMD engine?? thanks guys...
Prior to my 94 LS I had a 89 Toyota Cressida. I did not know it at the time but there was a known problem with the head gaskets in that particular 7mge engine series.
Only found this out after it had blown a head gasket & effectively totaled the vehicle.
As far as the original post . definately a head gasket should last longer than 3 yrs
- And not to give a hard time,and maybe im wrong. But my guess is that like the first time it happened due to lack of proper care, perhaps the same maintanance habits were resumed ?
I know this is a little old. just wanted to ad a thought about the op's original post. It sounds like maybe when they changed the head gasket the first time. That they may not have decked the heads to make sure they were flat. Any time a head is pulled it should go to the machine shop to get decked. This really true if it is aluminum. The cast iron heads you got away with not doing it . If you laid a straight edge and it looked flat. Aluminum heads just need to be perfect if you want the seal to last.
110000, average, cost, dealership, expected, gasket, head, headgasket, lexus, life, miles, replace, replacement, replacing, standard
