tail light replacement.
Old 01-22-05, 08:46 PM
reamemiya
reamemiya's Avatar
Default tail light replacement.
my tail light warning came on today while driving around LA.
it's the drivers side brake light that went out and i was wondering
which bulbs i use to replace these.
thanks
Old 01-22-05, 09:20 PM
Fiya
Fiya's Avatar
Mine have been out for about a month (I'm lazy) so I also need the bulb info, and is this a DIY, I have changed the headlight bulbs but the tail lights look like a more involved job.
Old 01-22-05, 11:15 PM
ACleanSC4
ACleanSC4's Avatar
I'm unsure which bulbs go in the taillight area, either 1156 or 1157...not sure..maybe i'm wrong completely...
taillight removal is required to change the bulbs, piece of cake to do...four 10mm bolts on each side...
Old 01-23-05, 12:04 AM
reamemiya
reamemiya's Avatar
thanks for the info!
Old 01-23-05, 08:12 AM
Dx3
Dx3's Avatar
The brake lights are a dual filament so they are 1157. It is also imprinted on the back of the tailight so you know what goes where.
It takes 30 seconds to replace your bulb.
Jonny
Old 01-23-05, 11:51 AM
reamemiya
reamemiya's Avatar
Jonny
thanks for the info. now what am i gonna do with these 1156?
Old 01-23-05, 02:57 PM
Dx3
Dx3's Avatar
The 1156 works on all of the remaining bulbs on the tails, just not the brake/tail that requires the dual filament bulb.
Let us know if you run into any problems,
Peace,
Jonny
Old 01-23-05, 08:21 PM
Fiya
Fiya's Avatar
thanks
Old 02-04-05, 04:57 PM
ngravatt
ngravatt's Avatar
Default auction
sell them on ebay.
i have a question about replacing tail lights. I replaced a bulb and now the parking lights dont work but the brake lights do work when i press the brake pedal. This is just on the driver side tail light. Has any one seen this problem before? and know the solution?
ps Its not the fuses or relays.
Old 02-04-05, 06:44 PM
Dx3
Dx3's Avatar
Originally Posted by ngravatt
sell them on ebay.
Explain what you mean by parking lights?
jonny
Old 02-07-05, 07:40 PM
GRAND_LS 4
3UZ-FEEEE
GRAND_LS 4's Avatar
jonny
Is when you turn on the first click in the headlight nozel.
Old 02-10-05, 04:31 PM
newyorksc
newyorksc's Avatar
hmmm i had the same issue (parking lights not working but brake lights working).. but it turned out to be a blown fuse.. but the first time i checked i could have sworn it was good..
double check your fuses -just to be sure.
kowala
09-23-14 10:48 PM
harvfran
03-22-11 11:48 AM
got56ry
03-23-08 04:36 PM
white93
Lighting
09-13-03 06:52 PM
Quick Reply: tail light replacement.
