Has anyone checked the math, trans fluid change , leaves alot of old fluid leftover!!
Old 05-26-01, 01:15 AM
Purplexed
Purplexed's Avatar
Unhappy
If you want to change your tranny fluid (LS4 holds 8.4qt total), you discard 2 qts, and leave 6.4 qt of OLD fluid. Who wants to be driving on old fluid.
In fact, if you change the fluid 4 times, it will still leave your 8.4 qt capacity transmission with 33.5% OLD fluid circulating.
Does anyone have a more efficient way to drain more of the fluid than 2 qts at a time??
Old 05-26-01, 06:19 AM
DevilDog
DevilDog's Avatar
The only real way to get all the old fluid out is to hook the car up to a trans flusher machine. Call around and see who can do it. May get expensive since you use type 4 fluid in your car.
Old 05-29-01, 08:40 AM
mdfdsc300
mdfdsc300's Avatar
the Lexus dealer quoted me $149 for a tranny flush via a machine for my '92 SC300. That seems pretty comparable to other dealers of different makes...
danno52
RX - 1st Gen (1999-2003)
04-08-19 06:11 AM
priobe
Performance
05-02-17 01:08 PM
DMPesso
Performance
16
12-10-10 11:55 AM
cdvmagic
Maintenance
01-31-07 11:44 AM
Quick Reply: Has anyone checked the math, trans fluid change , leaves alot of old fluid leftover!!
