Warning Messages on the dashboard.
I have a 98 LS 400 and my "tailight failure" message will not leave the message board on the dash. I had the blown bulb replaced and the message still will not go away. It comes on as soon as I hit the brakes. Has anyone had this problem before. I also think my washer fluid sensor is bad because it syas I need fluid but it is full, does anyone know of a price to get this fixed?
Welcome to CL. Please make you use the correct light bulb and correct bulb#. You has one or two burnt bulb, double check it again.
About the washer leverl sensor. I don't know how much the part will run you(shouldn't be more than $100.00), but the labor is 1 hr.
