1997 ES300 head gasket leaking problem
Old 03-30-05, 10:01 AM
ezwinner70
ezwinner70's Avatar
Default 1997 ES300 head gasket leaking problem
Hi there, I have a 97 ES300 and there is an external leak from the head gasket. I know there was alot of problem with te 92-96 camry/es300 with this problem and there was a recall. I checked and there's no recall on the 97, but can I get one? It may not be on as many cars, but the same problem happened again. Anyone have dealt with this issue lately?
Thanks
Old 03-30-05, 10:40 AM
ssultan
ssultan's Avatar
I haven't read about any such recalls on the 97-01 ES models. I have an ES and have experienced no such leak (touch wood). Whats the mileage on your car?
Old 03-30-05, 12:02 PM
ezwinner70
ezwinner70's Avatar
around 97k
Old 03-30-05, 12:24 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
Thanks
Are you sure it's the headgasket or are you confusing it w/your front bank valve cover gasket?
Old 03-30-05, 01:21 PM
ezwinner70
ezwinner70's Avatar
i'm sure it's the head gasket that's leaking. i had a family member mechanic check it out. how much is that to fix anyway?
Old 03-30-05, 03:47 PM
BruteSBC
BruteSBC's Avatar
ill look tomorrow for an open recall on our database....post your vin number for me and ill tell you what recalls if any are open, and ill check for a TSB for you.
Old 03-30-05, 07:45 PM
ezwinner70
ezwinner70's Avatar
thanks bruteSBC, here is the vin number
Old 03-30-05, 10:26 PM
93lexuses
93lexuses's Avatar
Thanks
There was a recall on the 92-96?
Old 03-31-05, 04:40 AM
BruteSBC
BruteSBC's Avatar
you have one open recall for recall XL7
steering wheel nut might not be tightened sufficently, and it says your status is "Not Completed" go to your lexus dealership for next oilchange or sooner and have them take care of the problem, it will be free, just tell them you have an open campaign XL7 on your car
sorry its not for a head gasket though
anyone else?
mike
Old 03-31-05, 09:48 AM
lexusk8
lexusk8's Avatar
Sounds like a rather difficult maintenance problem to look over, so I'm moving this to the Maint. forum.
Old 03-31-05, 01:27 PM
BruteSBC
BruteSBC's Avatar
only recall on head gaskets i can think of around those years was on the 3.0Ls in the pickups and the 4 runners. and that was a MAJOR recall, none that i can recall on the 1mz engine, these are pretty reliable motors, ive seen a handful of them need headgaskets in the last year, and we do easy 100 cars a day on a slow day.
Old 03-31-05, 02:17 PM
ezwinner70
ezwinner70's Avatar
thanks BruteSBC, how much usually is the cost to fix the head gasket from lexus? thanks
Old 04-01-05, 08:36 AM
BruteSBC
BruteSBC's Avatar
if you want, tomorrow i can look up the labor time for ya.
Old 04-01-05, 12:42 PM
ezwinner70
ezwinner70's Avatar
that'll be great if you can brute. thanks
texcorndog
01-14-12 07:06 AM
rich81
12-07-11 09:28 PM
sa23
03-07-11 04:34 PM
cham2526
07-24-06 07:37 AM
RedRacer
02-03-06 09:25 AM
Quick Reply: 1997 ES300 head gasket leaking problem
