Stripped ATF plug
You'd have to drop the pan each time to do a drain and fill or a filter change since you wont be able to loosen the nut. This fix would at best be temporary . Its a trick I use in construction.
It might be a better trick to use a properly-sized compression plug. That's a rubber cylinder sandwiched between 2 washers, with a nut and bolt going through the whole thing. Tightening the bolt squeezes the rubber, expanding the sides like a barrel and sealing up the hole.
I suppose these solutions are good for trans pan but impractical for oil pan. Is there a way for oil pan without pan replacement or rethreading?
Yes, the expanded rubber and pan hole would be in the same plane. This same plug, in a larger version, can also seal up that leak-prone coolant level sensor hole in the coolant overflow tank. They are usually sold in hardware stores in those yellow plastic drawers where a bunch of other handy small parts are kept (mirror clips, heat-shrink tubing, t-nuts, hole plugs, cane tips, brass grommets, etc.)
dcdyd
04-11-13 08:58 PM
