99' GS400 wheel bearing cost?
Old 04-30-05, 02:25 AM
Dbl400Trbl
Dbl400Trbl's Avatar
Default 99' GS400 wheel bearing cost?
Hey folks...
My rear pass-side wheel bearing is shot at 45000 miles (which sucks ) and I'm being quoted $500 from a non-Dealer shop for the work which was stated as mostly labor. Does this seem in the neighborhood of reality, or am I about to get juked? Thanks.
Old 04-30-05, 05:02 AM
TLW
TLW's Avatar
Originally Posted by Dbl400Trbl
Hey folks...
it is pretty labor intensive
the best way to tell if your getting your money's worth is to find out
what book time is on ajob like this
book time x hourly rate =$$$$
contact lexus service dept .....see what they
Old 05-01-05, 04:35 AM
Dbl400Trbl
Dbl400Trbl's Avatar
Default Cost at dealer = $700-800
The local Dealer quoted 750 which included the hub cap that they say typically should be replaced in the job.
Old 05-03-05, 10:22 AM
ssultan
ssultan's Avatar
Hmmm...not sure about the bearings on the GS...they might need to be pressed into place....on my old toyota I ran into a similar issue with the rear bearings being shot...ended up just buying the whole hub assembly which already contained the bearings...and it was a basic bolt on job...doing it myself took an hour longer than replacing the rotors....
carferna
GX - 2nd Gen (2010-2023)
19
03-30-20 06:55 PM
tman9999
RX - 3rd Gen (2010-2015)
01-24-18 09:01 PM
jangell
01-07-17 04:45 PM
patsc300
Suspension and Brakes
13
02-28-16 05:04 AM
mayad79
12-13-15 01:55 AM
Quick Reply: 99' GS400 wheel bearing cost?
