Vehicle maintenance log
For any car owner, it's generally a good idea to keep a log of all service and maintenance work done on your car, especially come selling time since you'd want to supply records and receipts to the prospective owner. If you're like me though, the number of papers and receipts can be so large that it would take a long time to thumb through them all and look for specific piece of info like what parts were purchased and the vehicle mileage work was done at, etc.
In order to make this process more convenient and less time consuming, I have been keeping an Excel spreadsheet and logging in all service/maintenance work done on my car, make special notes regarding each of the work intervals, and the vehicle mileage and date at each time. A couple benefits are that it's easy to make changes and additions to this sheet, and color coding makes it more visual.
I have attached a template of the maintenance log spreadsheet to this post, so feel free to use it and keep track of the work done on your car(s). If you have more than 1 car, you can make a separate spreadsheet for each of your cars, and keep them all organized
Not a bad idea at all Doug. I've got all mine & my wifes in file folders & in a file cabnet. as it is. I'm sure many though will find it very helpful.
I just update mine as I go, & file them in a folder. Not elegant , but works for me:
Purchase date: 11/15/2001 Mileage: 117,815
Vin # : JTXXXX1EORO199160
Mfg. Date 01/1994
JP Importz: Jason Pham 214-221-3135
Davenport contact # 972-612-3377
11/23/2001 Repair Drivers Side Brake Light
05/15/2002 Leaking Heater Control Valve replaced .
07/30/2002
Brake Rotors & Pads changed . Bradi Rotors , Rotex pads from
Ricambi Sport
Front & Rear: Mileage 130,345
12/06/02 Air Filter Replaced. 135,862
05/02/03 Power Steering Fluid complete flush: Mileage 139,004
06/05/03 Transmission Fluid complete flush Toyota T-IV fluid : Mileage
140,312
08/08/03 Cabin Air Filter Replaced: Mileage 143,216
08/14/03 Front & Rear Struts replaced, OEM components. Front upper Strut Assembly replaced.
143,322
08/18/03 4 New Kumho Ecsta HP4 716 Tires from the TireRack. Mileage 143,546 installed at Costco
10/19/03 Bosch Windshield wipers
12/10/03 BG 44K Fuel System Cleaner added. Mileage 148,423
BG MOA Oil Treatment added with oil change. Toyota oem filter
used.
BG Cooling System Flush added.
Complete flush of radiator and cooling system / Add 1.3
Gallons Toyota long-life coolant.
02/17/04 Brake Fluid Flushed by JP Importz:Replaced with Ate Super Blue
Fluid.
Coolant level checked and made 50/50. 149,318
03/18/04 EGR Pipe assembly replaced at Tines Automotive. New motor mounts &
transmission mount
installed by A-1 United Transmission (972) 278-9807. 149,566
03/27/04 Fuel Gauge Capacitor C-142 replaced on Circuit Baord. Work done
Jeff Tregre 972-296-3421
JeffTregre@comcast.net
http://www.circuit-technology.com/ht...f__tregre.html
152,151
04/01/04 State Inspection / Registration sticker applied. Oil Change 153,875
06/04/04 AC system checked for leaks / none found. 4 oz. of refrigerant
added at Blendair 156,729.
www.blendair.net Owners name: Mark
972-313-2025
Due: Next Oil change 158,875
09/16/2004 Oil Change with Mobil 1 Synthetic 159,515
12/23/2004 Tires rotated
01/10/2005 Current Mileage 165,500
Just started to have delay in Dashboard Instruments Display: Solution:
Replace
10uf 16v EC cap. Its on the processor or smaller PCB board. Reference is C212
03/07/2005
167,180 Oil Change to Mobil 1 Extended Life 15,000 mile
03/14/2005
167,565 Air Filter replaced.
03/22/05 Lower Ball Joints replaced (front) Tines $50.00
05/10/05
Mileage 168,475
Timing Belt replaced:
13568-59045 Timing Belt
13540-50030 Tensioner
13503-0f010 Idler Bearing Left
13505-50022 Idler Bearing Right
Front Cover Gasket
11319-50010
11329-50010
11346-50010
11347-50010 2 Total
11357-50010
90311-A0001 Front Crank Seal
90311-38036 Cam seals ( 2 Total )
Cooling:
16100-50022 Water Pump
90916-03084 Thermostat
16325-62010 Water Inlet, Gasket
16571-50021 Upper Radiator Hose
71538 Lower Radiator Hose (Dayco Part #)
Hayden Fan Clutch #2656
16307-50011 Bracket Support for Fan
Accessories:
Alternator Parts
90099-10192 Front Alt. Bearing
90099-10194 Rear Alt. Bearing
27370-75060 Brush & Holder
Power Steering Pressure Hose (rebuilt at Hose-Fast)
5060885 Serpentine Belt (Dayco Part #)
89255 Tensioner (Dayco Part #) (This part was modified)
89026 Pulley (Dayco Part #)
Drive Belt Bearing NTN 63011LL (A&W Bearing)
Electrical
19101-50020 Dist. Cap X 2
19102-50020 Rotor X 2
Spark Plugs
BKR6EIX-11 X 8
Mfg. Date 01/1994
07/30/2002
Ricambi Sport
140,312
143,322
used.
Fluid.
transmission mount
152,151
972-313-2025
Replace
03/07/2005
03/14/2005
05/10/05
Mileage 168,475
Front Cover Gasket
11319-50010
11329-50010
11346-50010
11347-50010 2 Total
11357-50010
Cooling:
Accessories:
Alternator Parts
Electrical
Spark Plugs
BKR6EIX-11 X 8
Banbuk77
RX - 3rd Gen (2010-2015)
09-28-18 05:36 AM
Ls4hundred
13
04-23-08 03:26 AM
