maint. suggestions
Old 06-28-05, 09:47 AM
idsrvit
idsrvit's Avatar
Default maint. suggestions
I have 85,838 on my 99LX 470...at 61,427 I had most of the recommended 60k maintenance taken care of. ...excluding the wheel bearings and height fluid. Spark plugs were not done since this is a 90k service. In all..I had
Engine oil and filter,
all fluids topped
tire rotate and pressure set to spec
eng air filter
air cond. filter
eng coolant
spark plugs per emission
clean/lub adjust front wheel bearings for 4wd
replace slip diff fluid
lub prop. shaft
lub drive shaft
inspect drive belt
inspect fuel lines/connections
inspect hoses
and all other scheduled checks.
My question is...we are about to travel (prob in temps well into 80's) and prob putting a good 4k miles on the car in a 2 week period. With the extra 25 k already on the car and just short of 90k miles total...are there any suggestive maintenance services you would suggest I have taken care of prior to my trip? Thank you for your time..
Old 07-04-05, 07:16 AM
idsrvit
idsrvit's Avatar
Default nevermind..
had it taken care of ....
Old 07-04-05, 09:55 AM
Tammy
Tammy's Avatar
Might go on fresh oil and filter just before leaving... inexpensive insurance with 4000 miles planned in a couple of weeks.
Jezo
CT 200h Model (2011-2017)
08-12-14 01:19 PM
Tensi
08-16-12 12:27 PM
Mistaspakl
Maintenance
10-10-08 04:11 PM
Colby
03-25-04 08:05 PM
Quick Reply: maint. suggestions
