finally did it jump to synthetic oil
Originally Posted by koolaidman
ive never used syn. today for some reason i descided to pull my oil pan off. with and to my amaze. there was very min dammage to piston side walls. i do oil changes 3months or 3k miles. from what ive seen from going with syn. they form a substance like graphite. i dare for some1 to take this test.
use conventional(sp?) oil. put a magnet on the bottom of the pan at ur oil change pull off the pan and look at the residue tell me what u find
do the same with syn. u will see a difference
PS- how have you been servicing your transmission? What ATF do you use? Could you pull your transmission pan and see how it's doing? While your down there could you also check your muffler bearing? I've been worrying about mine, starting to make noise and I just serviced them 10K miles ago and used synthetic bearing grease. Thanks man for the heads up
Originally Posted by PitBull
Koolaidman, that's a great name. You pulled your oil pan off for no reason and you were able to look up into your engine block and determine that you had damage to the piston side walls. WOW that is far out. I think I will start using synthetic oil right now based on your post. Thanks man for the heads up. Keep drinkin the Koolaid I will too
funny u should ask bout muffler bearing...i do recall a benz with mufler bearing. personally i think u have a lose nut behind the wheel
oil pan is nothing. takes 3 min to take off and another 5 min to put back on.
LOL pit, I think he missed your sarcasm?
GSquicksilver
02-09-06 10:07 AM
koreanpers
Maintenance
12
04-08-04 05:18 PM
