finally did it jump to synthetic oil
Old 07-07-05, 09:33 AM
b1gredek
b1gredek's Avatar
Default finally did it jump to synthetic oil
finally made a change to synthetic,,,,,,, i must admit i do notice a change.... my car seems so much quieter now....... the engine revs a little faster,,,, not sure if i am gonna get better gas mileage or not,, well see........
Old 07-07-05, 09:42 AM
np20412
np20412's Avatar
I don't think i've ever NOT used synthetic?
Old 07-07-05, 09:51 AM
damon
damon's Avatar
My 94 LS definitely got a little quieter after a change to synthetic. What that means , I can't tell you.
Old 07-07-05, 10:15 AM
lexusk8
lexusk8's Avatar
Tack up another one for the synthetic newcomers! Once you go synthetic, you'll never go back
Old 07-07-05, 11:35 AM
Cloud9
Cloud9's Avatar
which synthetic did you use?
I recommend Mobil 1 Fully Synthetic
Old 07-07-05, 12:01 PM
np20412
np20412's Avatar
Mobil 1 is what i've been using for a LONG time. 5w30, as recommended by lexus. I've got a bottle of 5w40 as well, but haven't used it in the Lex. I hear its not good to use any viscosity other than recommended, any truth to that?
Old 07-07-05, 01:24 PM
Fisher503
Fisher503's Avatar
Mobil ! all the way
Old 07-07-05, 01:53 PM
CompuMan
CompuMan's Avatar
Default Mobile 1 5w-30
I agree with LexSC888. I use Mobile 1, 5w-30 in both my 1992 Lexus SC400 and my 2001 Acura CL . Both run very on this oil. I have used this oil in all of my cars for many years.
Old 07-07-05, 08:02 PM
lexusk8
lexusk8's Avatar
I also use Mobil-1 full synthetic, 10W-30 grade in my ES. Oil is strictly changed every 5K miles, and I buy 5 qts from Wal-mart for less than $20. Awesome deal
Old 07-08-05, 06:55 PM
b1gredek
b1gredek's Avatar
mobile one with a toyota filter is the road i took...... so far so good
Old 07-08-05, 07:02 PM
PitBull
PitBull's Avatar
http://63.240.161.99/motoroil/ good info.
Old 07-14-05, 12:01 PM
damon
damon's Avatar
Despite my best intentions, I let the temp gauge in my 94 LS spike to its capacity before I noticed it last Sunday.
I shut it down & got some water in the coolant resevoir & was able to continue with my short drive. Found & fixed the leak. It was a bad o-ring on a heater bypass line that runs from the bottom of the Thermostat housing under the manifold back to the heater control valve.
Note, my LS coolant system had pressure tested A-OK ( high in fact ) when the TB & coolant & hoses had been changed the month before.
Despite my bad resource management, there was no damage to my 1UZFE engine. The extra-protection of Synthetics/Mobil 1 to extreme heat may have saved my a**!!!
damon
Old 07-14-05, 01:19 PM
PitBull
PitBull's Avatar
damon
That is a great point, any vehicle that is no longer under warranty, I would think synthetic fluids would always give you additional protection that would cover your rear.
Old 07-14-05, 02:32 PM
b1gredek
b1gredek's Avatar
wow glad to hear your engine made it with no problems,,,,, still dont know why i was so hesistant to make the switch back then
Old 07-14-05, 06:30 PM
koolaidman
koolaidman's Avatar
ive never used syn. today for some reason i descided to pull my oil pan off. with and to my amaze. there was very min dammage to piston side walls. i do oil changes 3months or 3k miles. from what ive seen from going with syn. they form a substance like graphite. i dare for some1 to take this test.
use conventional(sp?) oil. put a magnet on the bottom of the pan at ur oil change pull off the pan and look at the residue tell me what u find
do the same with syn. u will see a difference
Quick Reply: finally did it jump to synthetic oil
