ac compressor on/off too soon
Old 07-12-05, 01:17 PM
Booner
Booner's Avatar
Unhappy ac compressor on/off too soon
Been having problems with ac on my 95 es300 for 2 years. On very hot days, it does not blow cold air at all. On warmer/cooler days, it will blow cool air for a few minutes. Tried to find leak with dye but can't see no leak. Everytime i fill up refridgerant the compressor kicks on and off too soon and the air inside is not cold at all. When compressor is on I do hear hissing sound near the lower pressure side port. Can someone help me find what the problem is?
Old 07-12-05, 02:45 PM
CUMan
CUMan's Avatar
Sounds like your expansion valve is sticking. This is a very common problem on mid-90's ES models.
Do a search. This problem has been discussed numerous times.
Old 07-12-05, 03:53 PM
VVT-i
VVT-i's Avatar
You may overfilled you A/C system. Do you have A/C gauge when you filled up the freon?
Old 07-12-05, 07:21 PM
koolaidman
koolaidman's Avatar
sounds like its over filled...try to find an ac pressure gauge and tell me static pressure
Old 07-13-05, 12:19 PM
Booner
Booner's Avatar
Yes I have the psi gauge. Do you read it when the compressor kicks on and the can is shut? I had the valve opened all the way to release the coolant, psi was like 35-45 while releasing, then compressor immediately turn off/on in short intervals, I left the valve fully opened for awhile, but the can has pretty much the same amount of coolant left.
Old 07-13-05, 05:06 PM
koolaidman
koolaidman's Avatar
well then whats static on high side and low side
drwillis
06-13-16 06:03 PM
dworak
09-22-15 10:05 AM
actman
RX - 3rd Gen (2010-2015)
26
06-27-15 12:14 PM
dmd85059
07-09-07 05:05 PM
Olu
04-28-07 08:39 AM
Quick Reply: ac compressor on/off too soon
