i did a bobo
ok guy this eveing i was trying to change my fuel filter, when i went to turn the nut, on the filter..i kinda turned to hard an twisted the line, now i cant acelerate on full thotule, can i buy an after market fuel line, or do i have to go to the dealer? it was on my sc400.
Originally Posted by /Aerostar\
You can buy flexible fuel lines and just cut off the old lines and clamp in the new
PS. I ****in hate doing the fuel filter!!
I feel your pain. I did that once too!!!
I had to tow my car to the mechanic and get it fixed. I don't know about using flexible fuel lines. I'm assuming it's a pressurized system so there's a reason why they designed it that way.
Just cut the line and replace with rubber fuel hose. Be sure to flare the ends before clamping the hose on. I cut out my fuel filter because the nuts were frozen and couldn't be removed. I replaced it with a hose barb type filter and the rubber hose. Works like a charm and it cost me like $10.
but i am facing the same problem except that my fuel filter is rusted...
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
i took it to a local mechanic, he told me the fuel line has to be replace. I told him if it can be patched or any other alternative, but he told me that the fuel line is a high pressure line so it either has to order parts from Lexus or custome made. So.. that's just gonna cost me lots of $$...
so does it really work just to replace the fuel filter and replace the line with rubber hose??
its a 93 SC 400
I guess you don't think much of jeremyp111's opinion if you are soliciting the same advice he has already offered (and that you quoted).
In any case, what do you have to lose by trying what he says? Invest the same $10 he did, try it out and if for some strange reason it doesn't work (when it did for him, like a charm), you are just back to where you are now. There already is rubber hose in the fuel line- you just can't see it from the fuel filter, but it's up there just past the fuel tank.
The fuel filter area is more exposed to the elements- to make the rubber hose last as long as possible, I'd give it a extra layer of protection, like some old garden hose, split lengthwise.
Originally Posted by PERRYinLA
Surrrrrrre it does.
Get back to us when you're finished.
