ABS/VSC/VSC OFF lights on
I just got the lower ball joints replaced on my 99 GS4 and all three of those lights came on. The mechanic said they were probably due to come on given the miles, however the lights weren't on at all when i dropped the car off. Should i try to clear the DTC or check the codes? Or just take it to lexus and get it fixed?
Also are the wheel speed sensor and the ABS sensor the same thing? I've read other threads about these lights and its always one or the other.
clear the code and if it comes back there is a problem
these guys messed up that sensor
dont let him tell you it was time
i would raise hell considering its not a cheap part
Whenever you do supsension work you need to be really careful with those sensors
very easy to break them
but good for you ....dont let these guys think it was your fault
mandyfig
06-20-22 04:29 PM
