Fuel
Fuel
hey was up, listen im qurious , how bad would it be an this would be just for one night, to run my fuel line with out a fuel filter..like just run str8 fuel line? sum hav said it would be ok sum hav said no i wana know the facts on it?
the worst you can do is clog up your injector if the fuel is dirty which might cost you since you cant open them up to clean them out and you would have to replace them, but then again your fuel and tank might be relatively clean and it wouldnt be a problem for one night either way its your choice you still have a sock thats connected to the fuel pump that filters the fuel right in the tank let us know what happens
When engines had carburetors, you had a bit more play with or without good filters. But today's fuel injected and electronically metered engine demand clean fuel to function at all. The cost to repair what could be damaged is not worth it. If not a factory filter, rig in some type of fuel filter, even if temporary.
Super Moderator
Trust me from my current 3.5 year experience in Mexico with my RX...don't do it. I had my last fuel filter replaced 3 years ago after only about a year in Mexico and it was pure yuck. It is due for replacement at the end of the year.
since we're on the subject.. how offen do we change the fuel filter?? and is it Recommanded to go OEM or can i just get some aftermarket???
as for running without a filter.... WHY risk it when a filter only cost 20 to 30bucks(MAX)?..
archangels
RX - 1st Gen (1999-2003)
04-06-08 10:20 AM
